ray_cadman
New User
New to site, be gentle.
I am having an issue with Fuel or hydraulics, and not sure which direction to go first. 460 hours. great shape over all.
1. fuel and Hyd filters are new.
2. fuel should be good, no sign of water/debris on bowl
3. replaced bucket ram seals (4) 1 year ago. cured leak down issue
The issue is when I go to move forward/reverse (under load), it bogs/looses power and falls on its face, but stays running. when it warms up, issues are less noticeable.
This may be elementary for most of you, but I am an old school Mechanic. minimal Diesel. For a small tractor, the injector pump is pretty expensive for its size. 1k-ish, injectors are 100.00 each.
Can the hydraulics cause the bog...
Any suggestions will be appreciated...
