Identifying Ford Wheel Weights
Hello I picked up 6 Ford wheel weights at A auction yesterday and I need help identifying what model tractor they will fit. The number on the back is S60E-1076. Any information that would help me identify them would be greatly appreciated.
could the casting number be 960e-1065a and be about 70 pounds each? If so they fit 28" wheels 3 cylinder 2-3000 series after 1965
It might fit 30" wheels as well.I have several around.
(quoted from post at 20:43:09 12/13/20)
(quoted from post at 19:31:06 12/13/20) That casting number should read 960E-1076, not the other number I posted about 70 pounds each.
That is correct it is 960E-1076. Thank you.
My Ford 3000 came with cast iron weights installed. The FOMOCO # on mine reads ....960E-1076-8. Info I got from an 'old timer' Ford Mech. said that the -8 at the end means, they are 80 lbs each.
and fit the center hub with three bolts. Owners manual reads, only install a maximum of three rings/weights, per wheel.
Pic. of my weight#'s on my 3000!
