Hillclimber1
New User
Hi all - I recently bought the tractor from my next door farmer friend. He instructed that when starting from cold, to turn the ignition key to the left for 30 seconds, then turn to right to start. Currently I have the timing cover off to replace the front crank seal. i.e. air cleaner etc. off.
I looked into the air manifold - [b:7098ba3787]There was no heater fitted!!![/b:7098ba3787] just the threaded hole with a blanking plug.
I can buy and fit the heater [b:7098ba3787]BUT[/b:7098ba3787] but how do I get a diesel feed to it - where from? The injectors have a pipe back to the tank - from there? or is a reservoir required? I [i:7098ba3787]assume[/i:7098ba3787] that as I have a 3 position switch, I should be able to find the wire - is it normally inside the harness or ?
Thanks for any advice. Peter (in the UK)
