1953 Golden Jubilee
randy.wright
New User
I have an aftermarket seat on my tractor. Can some one give me a parts list to put a pan seat back on it? I know I need the spring, seat but there are also bolts and small parts I am not sure I will need.
Thanks
Seat is 8n 400-A. It came with a 3/8 inch X 7 1/2 inch bolt, washer, nut and Cotter Pin. The spring is NAA 404-A. The hinge is 8N 436-A. It came with various 5/16 inch bolts, lock washer and nuts. There is also a clip 8N 433.
If you're going to keep your Jube for a awhile you might want to order the Master Parts Catalog.
(quoted from post at 09:52:42 12/10/20)
A lot of us use the New Holland parts pages hosted by Messick's New Holland.
The problem with that is that, every since they changed the site a few months ago, it only lists the part numbers for parts that are still available from New Holland, so you can't get the part numbers for no longer available parts that you might be able to find used parts or after market replacements via a Google search of the original part number.
They are pretty easy to find at a local tractor yard.
9N/2N/8N, Ferguson, etc. will fit, but only the 8N and up had the flip up style.
If you want new, our hosts sell them. [b:8365fae4e9]Seat Parts[/b:8365fae4e9]
