Tractor was not charging battery. Showed same voltage on battery running and not running and ammeter at zero. Had reliable shop check
generator and they said nothing wrong with it. So I replaced voltage regulator (VR). Now it is over charging, showing close to 30 amps on
ammeter and 8.9 to 9 volts across battery. Checked ground at VR and genny and both show good continuity to battery ground. Suggestions?
