Company Logo Shop Now
Order Ford 4000 Parts Online
Ford 3 cylinder diesel 4000 engine tachometer change ov
mikewood869
12-08-2020 19:00:27
Is there a kit to change over from the generator/ alternator to the engine tach (under the oil filter)? It looks like there's a freeze plug under the oil filter. The motor is a 1968 (what the numbers on the stamped spot on the transmission). Then I noticed on our 1970 gas 4000 3 cylinder motor, where that freeze plug is, there's a spot for a breaker bar to turn it out. The alternator might be crapping the bed soon.
[/url]
Fordfarmer
12-09-2020 04:07:46
 Re: Ford 3 cylinder diesel 4000 engine tachometer change ov in reply to mikewood869, 12-08-2020 19:00:27
If it's a screw-in plug, the newer style drive won't work.
Shaun Wallace
12-08-2020 20:23:47
The oil pump drive and cluster have to be changed too.
Today's Featured Article - Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee ... [Read Article]
Latest Ad: Looking for a useable engine head for 1929 McCormick deering 10-20 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
