Proper hydraulic line washers/o-rings Ford 6600
DavidBTX
New User
In front of the seat the hydraulic lines come into the box with the control levers. We replaced all the lines. The shop gave us
o-rings for the banjo bolt seals, but it leaks. Can anyone guide us on the proper seals? We have heard bonded washers, copper,
and o-rings. I also looked in the abbreviated shop manual I have and could not find torque specs.
The seal that goes on the banjo bolt is an o-ring. The seal that goes between the fitting and the valve should be a square cut o-ring. I don't have parts numbers handy, I avoid the NH parts site like the plague.
Thanks. There is a recessed hole in the cube fitting that the banjo bolt goes through. Everyone thought the washer should fit inside there? I attached a photo of the recessed hole Where are the banjo bolt comes through and a picture of the hole in the tractor.
Where the banjo bolt comes through and a picture of the threads in the body of the tractor.
That recessed hole is where a "square cut" rubber o-ring goes. Not a copper washer, not a round o-ring. It's in the parts book, such as it is.
