Ford 3000 rear end sway bars
mikewood869
Anyone ever used the square boxed sway bars on 3000 rear end? I have the 1/4 inch bars and I'm waiting for them to bend.
https://www.amazon.com/gp/product/B01FRHXJ94/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
As long as you keep using the sway bars as pairs they won't bend. One side will be in tension before the other side can bend.
I bought a set from YT for my 2000. They work fine, just remember the put them on with the crook end up or you'll break something. As RM said, they bend when you only
use one.
After my post I looked at the link. Those are for larger tractors so the length may not work. I bought one from TSC that was labeled for 2000 but it was too long and
pushed the implement to the side. I was only using one and it eventually bent until it rested against the lower link, which put in just about on center. Three cylinder
2/300s used shorter bars.
