BogDownStreet
New User
My 861 spits oil out of the breather so I was topping her off with the MobileOne 5w20 I had on hand. Oil pressure was good, on the gauge, very rarely dropping down low temporarily under a load change. Finally changed the filter and filled up with Rotella t4 15w40 as recommended on a post here. Fired her up and the oil pressure is higher than my gauge, which goes to 80. After the engine is hot, at idle the oil pressure will drop back to 60 but otherwise it's above 80 at all times.
I know low pressure is bad, what about high pressure? What can I do to stop it spitting out the breather cap?
Out of concern I picked up Rotella 5w40 so I have that on hand now.
