Ford 172 CI engine exhaust manifold torque procedure
Hello, can anyone tell me the torque sequence for the exhaust manifold on a ford 172 gas engine for the 6 bolts? Also I'd the torque rating 40-50 ft pounds? This engine is in a 1963 Ford 4140 hd industrial tractor. Thanks!
-Jesse
My manual just says "evenly and alternatively" 40-50 ft-lbs torque.
So tighten them all incrementally. I'd start in the middle and work out.
Sorry to pick nits, and not that it would make any difference in the torque specs or procedure, but isn't that a single manifold for intake & exhaust? And the parts drawing doesn't show bolts, it shows studs with nuts.
(quoted from post at 10:05:18 12/05/20) Sorry to pick nits, and not that it would make any difference in the torque specs or procedure, but isn't that a single manifold for intake & exhaust? And the parts drawing doesn't show bolts, it shows studs with nuts.
Yes, the manifold is intake and exhaust is a single manifold. Mine had bolts not studs. Thanks for help so far.
-Jesse
