Married1971
New User
I have an NAA that the rear three point works fine. I bought a front end loader to add to the tractor recently. In order to feed pressure to the control valves on the loader I used a 'remote' controller that mounts on the top of the hydraulic case.
When I pull the knob out to send pressure to the loader nothing happens and no fluid comes out of the hose to valves, yet when I push it in the three point continues to work perfect - what gives??
If the three point didn't work I would suspect the hydraulic pump to be faulty, but it works just fine.
Does the lever for draft control have any bearing on this system either??
About to pull what little hair I have left out with this problem - help!
