I get one click each time I turn the key switch on but the starter does not engage. Jumping from the ignition terminal of the solenoid to a 12 volt source on the tractor starts the tractor so I think the solenoid and the starter are both working.
I think the neutral switch is located in the transmission and I cannot locate the relay(if there is one--I'm assuming the click that I hear is a relay) and the ignition switch is nearly impossible to get to for replacement.
Any suggestions?
Any suggestions?
