I need a hydraulic pipe and don't know what it's called or the part number. It is located by the hydraulic pump and is about 6" long. About 1/2" dimeter with a round flange on one end and a triangular flange on the other end. Each flange has three bolt holes and seal with an o-ring. This pipe/part is on other models using the J843 Shibaura engine. Any info would be appreciated. thank you, gregjo1948
Old Ford dealer braised mine where a hole appeared a decade ago, been working since. If that’s the issue?
Paul
Number 7---SBA3 TUBE
Is there a place on line that I can reference for Ford/NH parts. I know there is a site for John Deere that I go to that will render parts for about any John Deere model.
thanks, gregjo1948
Yep--there is a pin hole by the flange on one end. I plan on trying to repair it but, if it fails, I'd like to know where to get a replacement. I'm not a braise sort of guy. thanks Paul, gregjo1948
Yes, that's it. A previous post sent a site to visit which showed the part #7 SBA3 TUBE. Any idea where I could get the Tube, if I can't repair my leaker? thanks, gregjo1948
