Bryce Frazier
Okay so I got the tractor split, took the flywheel apart and it had oil inside it and around the clutch? Is this supposed to be some kind of a wet clutch for the SOS transmission? I've never seen anything like it. We believe it was hydraulic or rear end oil, rather than motor oil.
Also, are gas and diesel flywheels the same dimensions, with the exception of the ring gear? Can I simply order a gas ring gear and swap them onto my diesel flywheel?
Or.... Are the bendix the same inside the starts, and could I put a diesel bendix in a gas starter?
Does anyone have a part number for the thick rubber seal that goes between the engine backing plate and the back side of the motor?
Thanks
Thanks
