English-Ford
New User
Hey hey, so this got pulled apart a couple months back and some obviously damaged parts were replaced, pto support sleeve, various o-rings, and the dual power pump on the side of the housing. It all went back together, fired it up and we ended up having the exact same issue. So we split the case again and dug a bit deeper, this time the pto clutch actuator was disassembled, and we found a cracked spring inside of the housing, but nothing else has really appeared. Would this cracked spring explain the symptom? All clutch material was measured and checked out ok. Definitely not wanting to pull it apart a third time, so any help is greatly appreciated. Thanks.
