Bryce Frazier
Thanks for the previous advice on swapping stuff over. Today I started the tear down of my 4400.
I was planning on removing the front axle/bolster as one piece. However on the 4400 the front axle has a rear brace pin in the oil pan... So am I correct that I have to first remove the axle from the bolster and pan, and then remove the bolster from the tractor?
My other concern is, the replacement motor I got was out of a farm tractor and has a normal tin pan, will the heavy cast one off of the 4400 fit onto it? Same motor right? Thanks!
