Hey all,
It is finally time to change out my rear wheel. The Ballast has mostly leaked out over the years but not before rendering the rim useless. It has 8 lugs and looks like the center is still good but riveted on instead of bolted (so needs to be cut?) I got a quote from the local tractor wheel place - to cut center out, weld it back onto a new rim loop, buy new tube and tire and ballast it is $1700! :roll:
Was wondering if you guys had a suggestion to beat that price. Seems like that would be on the high end. I'm located in Maine in case y'all know anyone. I look forward to hearing from you.
Thanks!
Thanks!
