Have a 63 Ford 2000 4cyl gas, for the past two years its ended up twisting the pto shaft. Only used for bush hogging a couple times a year and some spots can be a bit rough and I blamed my 18 year old son who has has quite an ability to break stuff..but this time, he hasn't used it and its been pretty much parked because I haven't had time. Made a few rounds and was running rough, pushed in clutch and when I released the clutch, the pto wouldn't spin. Tried the lever, had the right feel (the past two times it would be stuck and got alot of grinding). Anyway, pulled the plate and its twisted in two and I cant get the front part out, so looks like I get to split it..not happy! Any ideas what could be causing it?? It hasn't hit anything, which I thought was happening so after the send I put a slip clutch on it, obviously didn't help! The last two I've put on have been cheap replacements, but surely its not a case of cheap bad metalurgy, got to be more going on here!
Since I'm going to have to get in there, what else should I do while its apart?
