TractorGuy60180
New User
I had to replace the head gasket in my jubilee. While doing that I drained the block using the drain hole on the side of the engine. Part of the gasket set was the new thermostat gasket, so I removed the old
one, cleaned up the housing and then replaced. After getting everything back together the old girl is running better than ever. The only problem is it doesn"t appear the thermostat is opening. I figure
either there"s no liquid behind it or the thermostat went out on me. Any tips on how to refill the block when you drain it completely? I don"t have another gasket and I really didn"t want to have to order a
new thermostat and wait for it to arrive. I"ve got fields that need to get worked this weekend before it rains even more. Here"s the process I followed to refill the coolant:
- Opened drain hole on block
- filled radiator until drain hole had liquid coming out steady
- closed drain hole, continued filling
- Once full, started engine and topped off radiator until it seemed steady
- closed radiator cap
After a few minutes of running around 1200 RPM, it went above 200 degrees. I shut it off when it approached 240, but never saw the temp drop (indicating the thermostat had opened).
