No lift: chapter 3
Nick
04-29-1999 14:16:41
well, I'm into this job for about $700 now, figuring oil and new pump and relief valve. I finally got nice oil flowing from the pump bleeder, where there was none before. I replaced the seals on both ends of the suction manifold, and installed the pump according to instructions, using two gaskets to get a bit of backlash in the drive gear. Filled all three housings with new oil, fired her up, and no lift! The arms are dead as doornails. Guess I need to do surgery to the pedestal, eh? Any suggestions? Thanks guys!
Nick
ken zent
05-30-1999 18:39:20
 Re: no lift: chapter 3 in reply to Nick, 04-29-1999 14:16:41
Had same problem--found check valve spring broke.
Replaced spring-everything ok now.
Bern
04-29-1999 17:17:31
Your unload valve in the lift cylinder is stuck in the dump posistion. Remove lift cover, pull out unload valve plug with a slide hammer(plug with threaded end), remove unload valve, clean it and the bore, replace o-ring, and reassemble. Unload valve is located next to main control valve, parallel to it. Cause of above mentioned problem? Sludgy oil and/or sitting around too long. P.S. I'm assuming we're talking about a 600-900 series or NAA tractor here.
Nick
04-29-1999 18:17:47
 Re: Re: no lift: chapter 3 in reply to Bern, 04-29-1999 17:17:31
Bern, sorry for my abruptness....yes, it's a 640, and it DID have sludgy oil, and was sitting. I'm after the stubborn valve tomorrow at first light,...well, maybe at 9-ish...
Nick
Nick
04-29-1999 18:13:54
Bern, wow, that's the sort of answer I was after! Now I feel like I approached this job backwards. I tried to go after the simplest things first.
Stay tuned.....nonstop coverage continues! Thank you Bern!
Nick
Sned.
04-29-1999 17:55:47
Well Nick I have learned some things from your endeavors. I have never had to work on my H.D. system...thankfully. I'm sure the day's a comin though .
Don Snedden...AKA Sned.
