Ford 6610S Clutch input spline questions
Texczech
I am replacing the clutch on this 6610S.There is a splined shaft that extends from the clutch that goes into a drive member that sits in the flywheel, drives the pto or hydraulics of both, I guess. I would like to change that splined shaft, what is the procedure to get this shaft out from the front of the transmission? Thank You!
Like Bern says, they come out the back. This is a 8x4 transmission. We got the clutch from Alexander Tractor from down in Texas. It came with everything.
Several yrs back my 6700 stopped moving on county road while transporting hay rake from 1 hay fields to another. As others stated it required split between clutch & trans case.
