Sherman trans on 841 leaking thru vent
Vafinest
New User
Hey guys I'm puzzled my sherman trans is leaking out of the breather vent. I had used hydraulic fluid then change to 80-140 trans fluid. I work on tractors often has a hobby so I know my way around. I have checked the fluid level. Does anyone know why it would do this and why some of these Sherman's have a vent and some dont also does the 4 speed trans have one on the 801 series tractor thank you.
Never heard of a "breather vent" on a Sherman auxiliary transmission.
A photo would help identify what you are referring to.
Dean
If the sherman is leaking it's probably the input shaft seal or rear gasket. As Dean said, can you post a photo?
