Ford 640 tractor help
So I have a leak coming from this plate under the tractor
Any help on what to do?
The hole is there on purpose so an oil leak from engine rear seal or transmission seal hopefully will not get on the clutch. The hole should have a cotter pin in it to jiggle around and keep the hole open. You can remove the 4 bolts and the plate will come off. Use a mirror or camera and have a look up in there.
The hole in the plate is supposed to have a cotter pin in it to rattle around and keep the hole open. The hole is to allow any oil leaks from the engine rear main or transmission input to drip out and not soak the clutch with oil.
