Does someone know if this drawbar is for a Ford Tractor and if so which one? Thanks
1965 through 83 for sure, possibly a bit newer.
Let me see the other side and I'll tell you if it's for the 3000 size tractors or 4000 size.
Like the others said, 2/3000 or more likely 4000/4000SU.
I think we paid around $80 for one for Luke's 4000. That didn't include the drawbar.
Del;
Not about the drawbar....Just wondering if you got a step fig. out for your loader tractor yet????
I took a close look at my Superior, and think you could weld a flatbar across the connection, at the bottom of the lft. side hook up of the hrol. lift cylinder.
Then fab up a footplate to weld to the face of that flatbar.
If you use tire chains on the rear, make sure to leave enough room between the step, and the tire. That would be the only way I could see, to have a place for a step for getting up on the tractor!!????
Gary
It is a ford drawbar and hanger, looks like the ones on my 4000 models
Though similar hanger for a 2/3000 is slightly different and I'm not sure what that difference is.
The draw bar looks to be for a 4000, 2/3000 draw bars are usually shorter after the drop.
