Preparing everything to get my one arm loader mounted to my 641. The loader came off an 841 and had a home made single bracket under the trans instead of the factory two brackets. The seller had another tractor in this yard that happened to have the two original under trans brackets so I snagged those as well. Here are four of the five factory mounting brackets.
Here is the home made bracket for under the trans. It is well made and 1/2 inch thick.
Here is the home made bracket next to the two factory brackets. I have not decided which way I will mount mine but will see which fits better.
I used a copper pipe in the hole of the hip bracket to weld the crack and keep the round hole. It worked really good.
I still have a crack to repair in the nub of the hip bracket, you can see it in the hip bracket photo.
