larry zielkowski
Got over a lot of issues with my 4500 ford loader tractor but my latest problem is after finding my hydraulic fluid all gummed up I drained , cleaned , put a new filter and fluid . Loader and transmission started working right away but the power steering doesn’t work before the tractor broke down and sat in the field the steering worked intermittently now it is rock solid wheels take a tremendous amount to turn almost feel like I might break something however if I lift the front wheels off of the ground with the loader they turn easy . Not sure where to start thought about disconnecting the hydraulic cylinder linkage to see if I can turn easier . Anyway looking for some help if anyone knows this system thanks Larry
