Everything including the pto was working. One day the tractor would not start. Had a couple mechanics
look at it and could not get it started. Local shop came and picked it up, dragged it around their lot trying
to jump it with no success. Returned it to me and told me they could not find the problem. As a last
resort I took the head off and found a bad head gasket, a 1/16th break between 2 and 3 cylinder. I
replaced and the tractor started right up. Hooked up the brush cuter to go mow the fields and the pto I
does not work. When I engage it there is no noise and of course it does not turn.
I disconnected everything and with the tractor off I can not spin the shaft. I put a bar in the hole through
the shift and with a great deal of force I can just move the shaft.
Where do I start to trouble shoot this.i have both operating and shop mannual and the fluids are full and
correct.
correct.
