Tractorcedric
- Location
- Garland. Utah
So many thanks for the trick to getting the TW30 to go together. I hooked up the starter and it went right to 1/4 apart. I just put a ratchet strap on each side to sorta pull it together. But it would not go the last 1/4 inch no mater how much I wiggled it. So I rolled it back apart. Since the suction tube was an issue I had placed a couple of nice thick flat washers under the tab that holds it in place. I also bought a 272285 oring from the dealer to put on it. Because the one I had put on it before was just one I had on hand. Now with the tractor split, I can't push the tube into the port in the back cover of the trans. I think the oring is to thick. 90 Duro 1.299 ID x .103 tkh. With two straps , I had some pretty good pressure against that oring and it was all greased up. Think I will get another 272285 oring just to make sure I have the right one. Tube goes right in without the oring.
