1964 Ford 2000 pto on off lever
Oasisvalley
New User
First time poster needs help finding a gasket and seal for the left side cover some call a differential inspection cover that has a shaft coming out of it that activates the pto. I could make the gasket but I really need the shaft seal. Thanks in advance for the help!
Welcome to the forum! Without looking, I'm going yo guess it's NLS from NH.
Have you checked this site? Or Dennis Carpenter?
Messicks site claims they have one of the gaskets (part number 9N4131)in stock for $6.94.
I actually had to search on a 641 instead of a 2000 as their site didn't return any hits except for the 200V Versatile tractors when I searched on "2000" as the model, but those parts should be identical between the 601 and 4 cylinder 2000 series.
They also list two different o-rings for the shaft seal depending on which shaft it is, apparently they changed the diameter at some point:
part number 128999 - .424'' ID x .103'' Thk ($0.85 ea)
part number 14457281 - .612'' ID x .103'' Thk (2.54 ea.)
And it says that they have 19 of each in stock.
