Good evening, first time posting. I have searched and read till my eyes have crossed. I have a few questions about the wiring for a 12vdc system
I have a 57/58 861, the man I got it from had done a conversion to 12V. All the wiring was a mess. I took the tractor completely down and have painted it and now Im putting it back together. Its been a project for myself and youngest son, 20.
It has the 3 wire Alternator, 6v coil, resistor, 2 position key switch and a starter push button on the dash. I have elimated the push button on the dash and installed the OEM safety starter button. I am also eliminating the 6v coil. The wiring diagram Im using came from here labeled K. LaRue.
1st question is: If I replace the coil with an internal resistor I should not need the in line resistor,correct?
2nd Question: The starter will continue to turn over even with the key is switched off. Is this the way its suppose to be. I realize the way its shown, its just turning the power on/off to the coil.
3rd question: On the 4 post solenoid, you got the battery lug on one side, the starter lug on the opposite, and two smaller ones in between. One of the small lugs goes to the starter push button switch, nothing is shown for the other lug. Do I run a wire from it to the battery?
4th question: Im not using an amp meter, do I just connect the hot wire that goes to the meter to one side of the ignition switch?
Thank you for any help. Scott
