Hydralic issue, ''53 Golden Jubilee
tsherman1967
New User
I am having an issue with the hydraulics on my '53 Golden Jubilee. When I increase the throttle from idle to around half throttle or more the 3 point hitch raises on it's on. The higher the throttle, the higher the hitch raises. The position lever is in the lowest possible position. Any ideas on what the malfunction may be?
There is no load on it. It just goes up when the rpms increase. Never used to do it. When it rises on it's own moving the position lever up and down makes no changes in its raised position. It stays raised until I reduce the rpms.
