Cranefixer
New User
I have a Ford 7610 without cab. Note this tractor sat with out use for about 2 years. I have changed all filters and oil etc.
When using the Aux port hydraulics only one of the ports provide pressure to lift the harrow/disc lift cylinder. If i swap the hoses it operates the opposite and forces wheels up to the frame. I have tried adjusting the load monitoring etc and even used the selector to provide only pressure to the Aux ports. I did not actually measue the pressue as of yet but it lifts the 28 foot wid disc with little to no issue. Could one of you fine Master Wrenches point me a bit in the direction i should look. Looking through the manual i have it does not really provide detail as to IF the load monitoring or the draft. position relates to the Aux hydraulics as well. Note a path to tank does exist as it does not deadhead.Thanks In advance !
