Re: Ford 640 wiring/battery connection
Author |
Bruce
04-28-1999 23:20:29
The following is a quote from the "FORD Tractor Shop Manual" : 1. A generator that has been inspected or tested must be polarized in respect to the battery it is to charge. Failure to polarize the generator may result in regulator failure. 2. The generator is polarized by disconnecting the field wire and the battery wire from their terminals at the regulator, and momentarily touching the two together. (Engine not running). This quick surge of current correctly polarizes the generator. Connect the wires to their respective terminals on the regulator. [End quote.] These are not MY words, but are from the Wizards who gave us FORD tractors! I would suggest that you: (A) verify that you have a 6v generator-many were replaced with a 12v unit that looks similar - check the tag. (B) verify that you have a 6v positive ground regulator - it may have been replaced with something different. (C) verify that the ignition coil is correctly wired - the "hot" lead from the key switch goes to the negative terminal on the coil. The positive terminal on the coil should be wired to the breaker point terminal on the distributor. (D) Connect the battery cables so the positive terminal on the battery goes to ground. (E) Polarize the generator as described above. If you still do not get proper charging, regulator may be faulty. Before changing regulator, verify that ammeter is good by checking continuity of the ammeter. Usually if the generator goes bad, there is NO output. (On my tractor, the brush holders in the generator rust-up, preventing the brushes from making good contact with the armature.) If the field coils in the generator go bad, you will get NO output. The "Ford Tractor Service Manual" covers models 600/601, 700/701, 800/801, 900/901. I highly recommend you get it! It has more info
Phil M
04-30-1999 18:38:04
Re: Re: Ford 640 wiring/battery connection in reply to Bruce, 04-28-1999 23:20:29
Thanks for the very useful info. I haven't yet had a chance to do the battery switch and generator polarizing. However, when I test the generator by connecting the leads of a meter to any two of the three terminals on it (with the tractor running), I am only reading about 1.5V. I assume this would indicate that something is wrong with the generator, and not the regulator, since I am measuring at the generator. Is this true, or could the regulator somehow effect this reading? Also, is it possible that not having the generator correctly polarized could cause it to only be putting out 1.5V?
Bruce
05-02-1999 09:29:11
Re: Re: Re: Ford 640 wiring/battery connection in reply to Phil M, 04-30-1999 18:38:04
I am not well qualified to address the theories of operation, but I believe your testing procedure may not be correct. The way I test for generator output is to measure the amperage put out by the generator, not the voltage. If you would like more info, e-mail me your address, and I can copy and send you some info. I highly suggest you obtain a copy of the "Ford Tractor Service Manual", as it covers your whole tractor in detail as well as giving complete coverage on testing and repair of the charging and starting systems.
Drew / Millington, MI
04-30-1999 16:26:29
Weird! I've got to think about this one. What in the generator needs to be polarized? The brushes?
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit
... [Read Article]
Latest Ad:
Needing good 70 series fenders. No rust or dents preferred.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
