So I finally got the new fuel injection pump installed. I get a good fuel stream at the bleeder valve. I'm just getting a trickle where the fuel line enters the engine. That may be normal, I'm just not sure. It didn't start, but by the time I had it bled and getting fuel through the battery was starting to die down.
I just wanted to ask if there is a proper procedure or trick to bleeding the fuel system and getting it running. In case I've done something wrong.
