Having a problem posting since I changed my Email address. Rcd. notification earlier that all OK. Then notified
problem still exists. If this post goes through jump right in with words of advice. In following IT shop manual
best I know how, I dont have R2, R1, Nuetral on my later 63 or 64 SOS trans. Tractor wants to propell forward.PP 84
says in regard to # 5 selector posn. "if servo 3 reading is higher than servo 2, it would indicate a leakage @
servo #2 Then on PP 88 The chart shows #5 posn. Servo 2 = 0 psi, and servo 3 180 psi.. which is what I have! This
book implies this is a check on system pressure relief valve. I have taken all pressure readings on 3 servos but
ar'nt able to diagnose. Rebob#1
