1972 4000 8 speed transmission with Independent PTO.
I'm replacing the Clutch pack for the PTO in my tractor. I have a Ford service manual dated 1966.
the manual said I need to check the gap between the hydraulic pump drive gear and the PTO clutch shaft, and install a shim if needed.
The manual does say it may not need a shim, when I took the tractor apart no shim was in there.
I know there was a change up in 1968 but I'm not sure what was changed.
I can't find shims on the New Holland parts pages.
Do I need a shim in there?
Thanks.
Thanks.
