Here are videos of the low side hydraulic pressures. First video is with the dual power disconnected at the pump and plugged, the
second is with it hooked back up. This is with the tractor cold, but you can see there is a noticeable drop in low and high idle
pressures. This is the one I posted about almost 3 weeks ago now with the air test videos. Does it look like the pressure
regulating portion is all working ok and my problem is in the dual power?
Hurst
Low Pressure Test DP Disconnected
Hurst
