Banjo bolt Ford 600 Marvel Schebler tsx 580
I've now bought a sediment bowl, washers and 3/8 banjo Part No: 86531362 from 2 sources including YT that are supposed to fit a Ford 600/ original TSX 580, but both orders the washer is too small for the banjo, the banjo won't insert thru the sediment bowl, and the bolt diameter is wrong for the carb. Looks more like 7/16. The first source confirmed that all of their bolts appear to be wrong and refunded.
YT is working on it.
There is a 7/16 bolt C0NN9A349B but in the pics it looks different than the 3/8 and has a different hole pattern for fuel flow. I added photos, but that usually fails when I post.
Anyone have an idea what's going on or where I can get the right bolt?
A lot of these parts are made overseas in countries that use the metric system. It is converted to SAE but still a small difference. That is why the
parts are off ever so slightly. I ordered the band type muffler clamps and they were to big. I shimmed them all to fit. I purchased a crankshaft
pulley that was made in India. It fit, but had to grind to bolster to make room to fit onto the crankshaft. To get reasonable priced parts I guess you
have to live with making them fit.
Not sure if the bolt and gasket are still available from CNH but both were as recently as a few years ago.
If it's still available from CNH (not a dealer aftermarket substitute) and you or order if from CNH, it will fit.
Be advised that banjo bolts and gaskets were supplied in both 3/8" and 7/16" sizes, though all 134 engines used the 3/8" bolt and gasket.
Take both tractor and carburetor model and serial numbers with you when ordering your bolt and gaskets.
Alternatively, DC (cannot state that supplier name here) has the banjo bolts but not the gaskets. They will likely fit.
Dean
