6610 Brakes
David G
The brakes on my 6610 will barely stop the tractor and are noisy, fluid is not very old. The tractor only has 3000 hours on it, but has been a loader tractor all its life. Are the brakes fairly easy to change? Both sides are acting the same.
(quoted from post at 12:53:59 08/30/20) The brakes on my 6610 will barely stop the tractor and are noisy, fluid is not very old. The tractor only has 3000 hours on it, but has been a loader tractor all its life. Are the brakes fairly easy to change? Both sides are acting the same.
From what I thought, you have to pull off the axle to change the brake. I know on one of our tractor, it might need the axles taken off to do the brakes. I guessing that the linkage it maxed out?
I have been into these tractors that had 12,000 hours on them and the brakes were still good. Every time I have been confronted with brakes growling on a wet brake Ford,we have changed the oil and adjusted the brakes and the problem has been solved. People have a tendency to put the cheapest oil they can find in them and it doesnt work well with wet brakes.Water in the oil will cause the same problem.
