7700 dumb question
Ok this may be a dumb question but I really don’t understand
diagnosing hydraulics. On my 7700 everything seems to work
fine until a little bit of use and everything warms up. It won’t lift
or fold the wings on my batwing mower and lift my 7’ 3pt
mower unless the tractor is reved over about 1300 rpms. After
about 15 minutes of pto work it has to be above 1300 rpms to
lift everything I’ve tried so far. I haven’t tried a grader box or
something non pto. I moved probably 25 4x5 round bales with
it last year and it seemed fine but was above idle the entire
time. The pump also whines when this is happening. A new
pump seems relatively cheap and would give me a good
reason to drain god knows what kind of fluid the previous
owner used and put in good fluid. Should I replace the pump
or is there something else I should be looking at. I know from
the 7000 row crop I have these pumps aren’t real great to
begin with in terms of modern day hydraulics.
Change the hydraulic filter, in case they are blocked... but.. you need to get a glycerin filled gauge off of ebay good for 3000 lbs and put a hydraulic male fitting on it... so you can check the pressure at the fitting cold and then warm... although I have seen clogged up filters do this twice..., more often, its is probably a worn out pump. when cold it will test good(maybe)... after about 3 to 5 minutes, it will test low and then lower. Rev the tractor up to 1300 or so and operate the hydraulic lever and have the gauge plugged into that port and watch it as you pull the lever... it will probably test well when cold and then test bad as it warms up... meaning as the oil thins a bit as it warms up, the pressure drops off due to wear in the pump housing. Its common for the hydraulic fluid to operate around 200 degrees after warm up.
Good place to start with hydraulics is a pressure test. But maintenance is pretty important too. You say you don't know what fluid it's got and haven't changed the filter so that's not a bad place to start. Is it full?
