800 gas, coolant leak
Bret4207
800 gas has a coolant leak somewhere in rear of engine. I think it's a head gasket but I can't see well enough to tell even after pressure washing. A lot of the water seems to be dripping from the bottom of the bell housing, but it may be running down and just dripping there as it's the lowest point. Are there any freeze plugs in the rear of the engine that is covered by the bellhousing? Can't seem to find a diagram showing that area. Thanks!
