961 lift arm dimension
Tom Bond
Would anyone know the dimension between the 2 black lines I marked on the lift arm pic? I can't find it anywhere. I'm trying to fit my newly made sway bars to my 961. One side fits but kind of sloppy. The dimension is approximately 13.5" on that one. The one in the pic is about 12.25" and the bar is too long to fit those holes. I'm sure new ball ends were welded on at some time in it's history and just cut too short. Ideally, I'd like to get them back to spec if that is available. Otherwise I guess I'll just do some cutting and fitting and wing it as close as possible to make the bars fit. Or if anyone has an original bar they could measure for me would be greatly appreciated. Thanks!
Immensely! Thank you! I owe you one. I'm hoping to just find an original unaltered set and swap them out. One side came off no problem. The other side the pin is froze solid in place after I removed the cotter pin. I guess just some soaking with Kroil for a few days and maybe some heat if necessary. Unless you guys have another trick that will work better. Thanks again!
