Tennessee Ford 600
New User
Bought a 640 a couple of weeks ago. It ran well when I looked at it but when I got it home the carb was dripping and had been dripping for a long time as the oil filter that he previous owner painted to match the tractor had been damaged over time.
When I tried to start it the bowl was definitely overflowing into the air intake and running out there also.
Took the carb apart to check the float. The carb had a repaired spot on it and either was stuck or sunk. I ordered a float, needle, and seat and installed.
The carb was really clean, but cleaned it out with carb cleaner, replaced the gaskets and put it back on the tractor.
Also replaced the spark plugs, oil and filter.
After that it fired right up but had to pull out the choke to keep it running. Previous owner said he never had to choke it.
It will only run with the choke pulled out and stalls regardless of throttle position when you push it in.
So where do I look next?
Thanks!!
Thanks!!
