WAS CHANGING MY OIL FILTER ON FORD 3000 BECAUSE THE GASKET LEAKED. TOOK EVERYTHING APART AND NOT SURE HOW IT GOES BACK TOGETHER.
OPTION 1: VIDEO I WATCHED SHOWED BOLT WITH PAPER GASKET ON OUTSIDE OF HOUSE FOLLOWED BY RUBBER GASKET ON THE INSIDE AND THE SPRING WITH LIP FACING DOWN THEN FILTER.
OPTION 2: VIDEO I WATCHED DID THE SAME WITH BOLT WITH PAPER GASKET ON OUTSIDE OF HOUSE THEN ON THE INSIDE THEY WENT SPRING WITH LIP FACING UP AND THEN RUBBER WASHER AND FINALLY FILTER.
I CANNOT FIND WHICH IS CORRECT.
LOGIC TELLS ME OPTION 1 BECAUSE THE RUBBER GASKET WOULDNT BE SEALING ANYTHING IF I PUT IT ON THE FILTER SIDE BUT I'M NOT FOR SURE. AND THE SPRING ORIENTATION I'M EVEN LESS CERTAIN
