crankyfranky
my 1963/64 ford 200 4 cyl started missing a couple of days ago. it all started when i tried to start is one morning and i heard something sharp while cranking. the engine started and had a cylinder miss. i checked the cylinders by pulling each wire until i found the suspect cylinder. i then checked for spark and even swapped plugs with a known good cylinder but the miss stayed put. i can hear a definite miss in the exhaust and nothing at the carb. i think it may have stuck a valve and got tagged by the piston. is that possible??? can i remove the valve cover without removing the gas tank and hood?
