Jubilee hydraulics.
Adknaa114
New User
Hey fellas, second post in the forums and I was hoping someone could help me out with my issues. I have a 1953 jubilee that Im having hydraulic issues. It will not lift hardily anything at idle and barely lift my 4 ft brush hog at wot. However it will Not settle an inch over 3 weeks of sitting with the bush hog up. I have changed all hydraulic fluid and I was assuming I had a weak pump but wasnt sure on how to test or if anyone else had other options. Thanks
(quoted from post at 02:51:28 08/06/20) Hey fellas, second post in the forums and I was hoping someone could help me out with my issues. I have a 1953 jubilee that Im having hydraulic issues. It will not lift hardily anything at idle and barely lift my 4 ft brush hog at wot. However it will Not settle an inch over 3 weeks of sitting with the bush hog up. I have changed all hydraulic fluid and I was assuming I had a weak pump but wasnt sure on how to test or if anyone else had other options. Thanks
onnect gauge, chain lift arms down, command LIFT, observe pressure, compare measured to spec.
