Tennessee Ford 600
New User
Bought a 1955 600 that was redone 5 or so years ago.
The carb had obviously been leaking as the paint on the oil filter below the carb was damaged. I pulled the carb apart to check the viton needle and seat, but found a soldered float. The carb is obviously not orginal but was pretty clean inside. I ordered a rebuilt kit and a float. So do I replace the carb or run this ebay special? If I replace it, with what?
Also there was no sediment bowl. Should I install one or is it better to install an in line filter?
Thanks for the help or advice.
