How much play should the rear axil shafts have when they are off the tractor but still in the axle tube, mine has about 1/2 to 1" of play. I have to replace the pinion bearings and need to split the tractor. I am unsure if the pinion bearings went bad from to much play in the ring gear/axle shafts, low fluid or to much play in the pinion gear. The pinion gear does move back and forth a little but the front bearing is bad(it Ripped the top and sides off of it but left all the bearings in it). also the ring gear cluster does look like it was hot at one time. Thank you for any help you can give.
