FORD 4610 I-D the year of MFG
I just bought my first tractor from my Uncle's estate its a Ford 4610 II the serial number stamped in the block is BC32747 the sticker under the hood matches the stamp it is a model DA314C I have not been able to find the Year it is. Any help? I should note that it was made in England
it should be a 1990 model, the "BC" serial numbers started that year, Basildon factory did odd things with their running serial number sequence, so if you'd get the tractor unit number off the hood tag, we can get it down to the day and shift assembled
(quoted from post at 12:38:06 08/01/20) it should be a 1990 model, the "BC" serial numbers started that year, Basildon factory did odd things with their running serial number sequence, so if you'd get the tractor unit number off the hood tag, we can get it down to the day and shift assembled
Unit 9M05B
