Cape Fear Scot
I've done a bunch of work to my 4000 SU this Spring and Summer, including (not limited to) new "freeze plugs", new hoses and belts, new steering wheel, fuel lines, valve cover gasket, oil pressure switch, etc, etc.
I've owned this tractor for almost 20 years. The power steering has never been quite right on it- it's always leaked and lost fluid, and I've thought it wasn't up to snuff- but it worked "some", and I've always been able to steer the tractor with no problem.
I had to do some pulling on the old steering wheel to get it off, and I did a little bit of pounding with a soft hammer and block of wood to try and seat the new one, as the splines on the column are worn off. I also topped off the power steering reservoir with hydraulic fluid. However, the tractor was harder to steer after I got it all put back together than it had been before. I didn't give that much thought-figured the cause would reveal itself in due time.
When I went out to mow a couple of days ago, I had some heavy mowing to do. All was well for about 30 minutes, then suddenly I was surprised to see hydraulic oil coming out from under the steering wheel and running down the column and gas tank cover. I had never seen this before.
I did some research on this forum, and someone had suggested changing the power steering filter- that the system might be building up too much pressure and blowing oil past the seals. So, I did that (changed the filter) just this morning, started the tractor up and there were no leaks.
So- I went out to mow again. The tractor was easy to steer, and all was well for the first 15-20 minutes, then I noticed hydraulic oil coming out at the power steering pump- it appeared to be coming out at the big O ring- where the reservoir/housing meets the pump. I kept mowing,and 5 minutes later, it was pouring out of the top of the column again! (The hydraulic oil was milky-looking).
Can anyone help me diagnose this problem?
